What are the default login credentials and web access details for the IR900?
Default settings: LAN IP = 192.168.2.1; Username = "adm"; Password = check the device nameplate. Access the web interface via http://192.168.2.1 (HTTP enabled by default). Ensure your PC is on the same subnet (e.g., set PC IP to 192.168.2.X) and disable any proxy servers before logging in.
