Modem replacement for IR615 HW 30108
Can someone advice on a list of compatible modem for IR615 HW 30108, EU region, capable of 2G and 4G? If someone has a 4G model of this router, EU model, the first eight letter of IMEI indicate the hardware model of modem.
Hi, you can find the information on the ordering guide of the IR615. It will be the IR615-S-FQ58.
Thanks for your answer.
Yes I read that document,
and noticed that IR615-S-FQ58 is a model with included a 2G/4G modem for
EU countries. I need to replace modem card, on my routers with old 3G
PCI card, therefore I'm asking support if exist a list of 2G/4G modems
compatible with IR615-S HW 30108. A real picture of a label of a
IR615-S-FQ58 router could help also, as modem model can be identified
from IMEI number from site imei.info.
It is a 4G Quectel module. You would have to replace the whole router, or ask your sales contact if you can ship the routers to have the modules swapped as there are other settings that may need to be changed. Please check with the reseller or salesperson you got it from to check if we can replace it for you.
Hello Jay,
Thanks for reaching us. The IR615 you have is IR615-S-U(PS08/30108), which is Euro model. And it is 3G only.
I understood that you are looking for a mini PCIe 4G module (you call it as modem) to upgrade the IR615 from 3G to 4G. And you found the IR615-S-FQ58 is the right model, so you want to know what the FQ58 mini PCIe module is.
Unfortuantely, to manage the quality of the InHand products, the hardware module is not swappable. It means end user is not supposed to swap the module. And even if the end user swapped the module (Removed PS08 module and added FQ58 module), the IR615 will not be able to work as the fatorcy setting is mismatched with physical module.
Not sure how many IR615-S-U units you have. If it is just one unit, I recommend you to contact the supplier (where you bought) to see if they can help to trade a IR615-S-FQ58.
