How to import the configuration
Method for importing configurations: Click "Administration >> Config Management >> Config Management >> Browse", select a configuration file, and click Import to import the configuration file to the gateway.
Method for backing up current running configurations to the PC (common): Click Backup running-config.
Method for backing up the startup file to the PC: Click Backup startup-config.
Method for restoring default configurations: Click Restore default configuration and then click OK.
