Factory default username and key:
Username: edge
Password: security@edge
The EC300 device defaults to creating root at the factory, but login is disabled. If you need to use the root user, please manually modify the system configuration and enter sudo - s to switch to the root user. The user edge is in the sudo group, so you can use sudo under the edge user to execute system level commands.
Username: edge
