How do I access the web management interface of the ODU2002?
1. Connect your PC to the ODU2002’s LAN port via an Ethernet cable. 2. Set your PC’s IP to the same subnet as the ODU2002’s default LAN IP (check the device nameplate or official manual for the default IP). 3. Open a browser, enter the default IP, and log in with the default username/password (found on the nameplate or in the resource center documentation) to access the web interface.
