Help configuration VPN router IR915L vs Meraki Firewal
It is a pleasure to greet you and request your support to know if any of you have carried out VPN tests between an IR Router and a Meraki device or better yet, how to configure the IR so that all the data is sent to a private IP address in a linear way.
I share a link where they show Meraki VPN client configuration parameters
https:// documentation.meraki.com/MX/Client_VPN/Client_VPN_Overview
Hey JD, the link shows how to set up the client on the Meraki. Once that is done, you just need to create the tunnel on the IR915. If you got to VPN>L2TP>L2TP Client, you can set up a tunnel by putting the Server IP.
