Dial Switch on IG502
  1. The pull-down resistance is OFF by default, and the dial switch is close to the non-antenna side.
  2. The corresponding relationship of dial switch is as follows:
  1. Interface 1A pull-up resistance
  2. Interface 1B pull-down resistance
  3. Interface 2A pull-up resistance
  4. Interface 2B pull-down resistance
  1. In the field application environment, if there are multiple nodes in the RS-485 bus network and the network is unstable, the pull-down resistance can be adapted accordingly.
  2. The pull-up resistance and pull-down resistance are both 750 ohm.
