Can I manage the router using SMS commands?
Yes, the router supports SMS management, which allows you to restart the device or manually connect/disconnect the network via text message. You must enable the function and configure the allowed mobile numbers. You can also set a "Status Query" command to check the device status or a "Reboot" command to restart it remotely.
