When viewing an IR302 in Device Manager, if I select the Cellular Signal tab and click on the little clock button beside the "Cell ID" it pops up with "Cell ID History" showing a log of the cell towers/frequencies that the modem/gateway has connected to (along with connection timestamps). This is an awesome - thank you for including this feature! To make this feature even better, it would be amazing if we could assign a description/label/name/nickname/tag to the cell IDs in order to make the list/log more readable, and/or have the ability to export the list as CSV (could then name the ID's in Excel).
Being able to quickly assign a name to a Cell ID would make the "Cell ID History" functionality even more useful when checking the status of a device / identifying an issue (quickly tell whether it's bouncing between towers/frequencies) as well as assist with troubleshooting this issue. Doesn't seem like it would be that difficult to implement/maintain (maybe it only allows/saves up to 100 cell ID & name pairs). If considering building this naming functionality into Device Manager, then please allow at least 30 characters so we can be somewhat descriptive in the name.
Thank you for your consideration.
