InHand IG900 Edge Gateway Optimizes Factory Heating Control
A factory uses water source heat pumps for daily heating. When heating is insufficient, air source heat pumps are activated to make up the deficit. Previously, the on-site SCADA system or cloud platform collected water source heat pump status and factory temperature to decide whether to start air source heat pumps, leading to potential control delays.
InHand IG900 Intelligent Edge Gateway — supports on-site edge computing, real-time data collection, and local logic execution, enabling autonomous heating control without relying on remote platforms.
Deploy IG900 to collect real-time factory temperature and water source heat pump operating status locally.
Embed the heat pump startup logic into the IG900 gateway; the gateway autonomously judges whether the heating is sufficient based on the on-site temperature and automatically activates the air source heat pump when needed.
Eliminated remote control latency, realizing instant response to heating demand.
Reduced reliance on SCADA/cloud platforms, improving heating control stability.
Optimized heating efficiency, ensuring stable factory temperature with lower energy consumption.
