1. Ensure the system is running normally (green STATUS LED flashes at 1Hz). 2. Locate the "Recovery" button behind the removable cover on the right panel. 3. Press and hold it for 10 seconds until the STATUS LED turns solid on. 4. Release the button— the device will reboot and restore factory settings. The process is complete when the STATUS LED resumes flashing (≈30 seconds).
