How to realize time synchronization on IG502 with private network?
IG502 time synchronization is realized through NTP. The default NTP server address is the public network address.
If it is a private network, it is impossible to access the default NTP server address. So you need to build a private NTP server, after NTP synchronization is successful, the system time will be written to the RTC.
